mms problems
stovetop
15
When I receive mms messages that are animated on my epic they are not animated. Instead I just get a still image,whereas it should move. They worked fine on my evo. Is anyone else having problems with this? Do I got something set wrong or does this phone not support animated mms's. Go
havent receive any yet but i know it doesnt work over wifi it says download but never downloads for me
Odd. When I open message and choose to save to sd card then go to the file I saved,it amimates as it should. But it wont animate on the messages. Strange.
Then its the sms app that doesn't support annimated gifs, have you tried handcent or chompsms?
No havent tried them. I use the stock messaging app that came on the phone. I' ll try them and see if it works.
z1hallitsee
