Mms problems
dmc1964
12
I have a sprint note 3 unlocked and I can't receive picture mail on tmobile
It could be an APN issue.
Create an APN that is as follows: NAME;T-Mobile,
APN; epc. tmobile. com,
MMSC; http:// mms.msg. eng. t-mobile . com/mms/wapenc .
APN Type; default, mms, supl
APN Protocol; ip4/ip6.
Leave everything else alone.
Or, if Andre Sierra's suggested settings don't fix things, try this:
APN: epc.t-mobile.com
If it’s an LTE Device, use: fast.t-mobile.com
Proxy:
Port:
Username:
Password:
Server:
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy:
MMS port:
MCC: 310
MNC: 260
Authentication type:
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
Android since v1.0. Linux user since 2001.
Thanks Crashdamage this is currently what I have but I just can't receive picture mail I hate to think that I'm not going to get it to work but this is where I'm stuck on the sending but not receiving .
Does your mobile data service work for email and web surfing?
Have you tried dialing 611? If so what did they say?
Edit: Fixed a typo in the settings I posted. Added the '-' in 'fast.t-mobile.com'.
KidColoringPage
