mms question, help appreciated
jeromesnightmare
i've been using snapseries miui 2.10.12 i believe and when i use the build.prop mms fix, it allows me to send pictures just not receive them. i've tried manually inputing the apn but it just won't work. any help would be appreciated as i've been all over google to no avail. it also doesn't work with henry's miui the cdma version and anything i use his virginmobile patch on.
Sent from my Marvelc using Android Central Forums
Richie Q
