Mobile Data Issue on VZW Note 7 (using on T-Mobile)
anon(9780053)
Banned
Jan 1, 2016
270
Lost mobile data usage........6 hrs........apn settings seen right unless you can sgare yours,,,,,,,,,btw shows no wap setting..........before i have to can it or return for repairs
Re: No mobile data apn tmobile seems right may be dead device im lost
It shouldn't really need repairs. Have you tried a reboot and cache wipe from recovery to see if it helps it out of its funk?
Lol
worth a try;;;;;;;;;did 3 resets
Hm.. Interesting. Try removing the SIM / replacing it back in and rebooting. See if that helps. If the APN settings are right it should work. The only thing I can think of causing the issue could be a local network issue with T-Mobile but usually that isn't the case.
Popped in ole sim card and all gone; 4 g stayed on when turned off wifi' but new tnmobilr gave me 2 g 4 g and 3 g but none had data when i turned wifi off then mobile data icon dropped out; samsing said device fine sim not so nor data 1 day after sim inserted'
My hubby had alot of issues when he took his LG G3 from Verizon to T mobile. nothing worked right and he could never receive system updates.
I'd go to T-Mobile and get a new SIM to see if that helps.
they refused...............said will charge me 20///all bs
Complain to John Legere on Twitter... He should be able to get you a replacement sim free since this is a service issue, not just buying a new sim
The data worked once you initially switched and just stopped recently -- correct?
Carriers also tend to be less helpful with connectivity problems if you don't have their phone... But hopefully it is just a bad sim which is an easy fix
riddle me QUICK NOTE 7 DATA DROPS EVEN SHOWING BARS
most times, when disable wifi 4g would jump ship. it would show 3 bars and no 3 g or 4glte. just ordered another sim.
i feel its in vain. I HAVE UNLOCKED DEVICE, HOW ELSE WOULD I MAKE CALLS. for the most, data drops, wifi ok but when data dies no mms ability. yes you are and i are stumped. wont admit it but WAS or is vzw device, but tmobile sim service. say it. i can take it. it is unlocked period.
Re: riddle me QUICK NOTE 7 DATA DROPS EVEN SHOWING BARS
That just meant you had cell signal for calls but no data. I have to agree something wonky is going on since the VZW Note is capable of working on T-Mobile.
Hopefully the new SIM will fix it for you.
Because even though all Verizon phones are factory unlocked...the Verizon firmware locks the LTE bands for use on AT&T and T-Mobile.
Just install the carrier firmware using Odin and you're good to go. Should be AP, CSC, .pit, and a couple more I'm missing. Don't have to mess with root or even APN settings once you install your carrier firmware. Then things like VVM work ;)
Aren't you still within the return time frame for Verizon? It might be best to return it to. Verizon, get your money back and buy the T-Mobile version.
It doesn't do this. It's unlocked and will work with any SIM. That's what it means by being unlocked. You're describing a locked phone.
radavojnovic2016
