i like the one from mippin "battery widget" better it's a widget with the % on it when you click it it lets you turn off/on your wifi,...gps,...and also takes you straight to settings. it's not a full running program like the others that kill your battery!!!theres turn on a program when you click to check them. use your app killer to check which ones are allways running.
