• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
motion control gestures
usguyver
809
4
I can double tap my screen off but I can't seem to double tap my screen on I'm not sure what I'm doing wrong.
NEXUS_HTC_PS
968
That sounds backwards
Digitally assigned space taken up by my Chromebook, M9 or N9 <(•.•)>
usguyver
809
4
no what I mean is I can't double tap it on but I can tap it off o the lockscreen and the motion jesters are on.
IAmSixNine
3,157
72
I dont think you can tap the screen to turn it off.
I think double tap to wake is it.
davidtm
246
Instead, you can add a power button next to Home, Back, etc that will allow you to turn the screen off
Sent from my SM-T530NU using Tapatalk
anon(7901790)
2,403
You're correct. I tried to double tap to sleep and it didn't work. Double tap to wake works though. i don't use it much though. I have the dot view case and it automatically wakes when I open the cover.
Edit: According to what I've read, you are supposed to be able to double tap to wake and sleep. I can get it to wake, but not to sleep.
