Moto X: Power on greeting
Re: Power on greeting
I don't believe you can. Perhaps there is a hack available for rooted phones.
Thanks for the reply. Yeah. I've tried everything. I bought mine from the Verizon store, I never set the name. But for some reason my greeting name is a lowercase "s" that's it, just a "s". My question is why or how did my greeting name just be the letter "s" . Stupid we can't change that stock..
How do I change the banner greeting?
To display or change your greeting:
1. Press OK > Settings/Tools > Settings > Display > Foregrounds > Greeting Banner.
2. To change the greeting text, scroll to the greeting and enter text using your keypad.
– or –
To turn off the banner, scroll to the Greeting Banner check box and press OK to clear it.
3. Press Done (left softkey).
– or –
What device/app are you referring to?
I just erased mine while reseting fabric configuration, and theres no going back, I've already checked with motorola :( so if you do this you can get rid of that greeting!
sidebin12
