mount issue - Using sonofskywalker
Boggus
81
3
Download new rom and the selected features. I select wipe data and cache and the process starts. I get a message of cant mount SD card and the install stops.
Phone goes into Clockwork Green mode after stating it will skip the format of /s d-ext.
This is how it starts:
Installing:SDCARD:/clockworkmod/download/www.adbdev.com/sonofskywalker3/Blackhole_Fascinate_4.2.zip
Finding update package ...
E:Can't mount /dev/block/mmcblk0(of /dev/block/mmcblk0p1)
(Device or resource busy)
E:Can't mount SDCARD:/clockworkmod/download/www.adbdev.com/sonofskywalker3/Blackhole_Fascinate_4.1.zip
Installation aborted
you need the new red cwm. green wont work. dont use rom manager, its still broke.
Khalequzzaman
