Mount SD for Mass Storage via WiFI?
gordol
409
14
Is there an app that will enable mounting the SD card to my Windows PC via WiFi? I've had multiple SD cards get corrupted in my Droid X in the past few months, and I believe it's due to "issues" when unmounting from the USB connection, so I want to go wireless. Unfortunately, there are a couple of apps I use that sync to the desktop via Mass Storage mounting only.
WiFi File Explorer should do what you want.
Thanks. That looks like something very useful and I'll certainly give the free version a try, but from its description is not what I am actually looking for. I'm not looking to merely browse and manage the files via my web browser, I am looking to wireless mount the SD card as a mass-storage device the same way it would be mounted via USB cable so that apps such as Documents To Go and eWallet can sync wirelessly rather than via USB.
paradigm76
