Multicolor LED Notification light?
recDNA
8,745
135
63
Is there one?Can it be controlled with common apps like lightflow? Lots of colors? Thanks!
Lightflow can. Or the Xposed LED control if you have (or want to install) Xposed.
Do you own a Note 9? How do u know there is one & it can be controlled in Oreo?
I know the Note 9 has an LED indicator, I have seen it. I have a note 8 right now running Oreo and lightflow is able to run my LED to change colors for different notifications.
That's great that it will have an LED notification light! I kind of figured that would happen. Samsung is good about that kind of stuff.
I know it works on Note 8. Just waiting for someone to try it on Note 9
Well unless you can contact one of the youtubers who have received the review models then we will have to wait until the 24th when the phone is out(or 23rd whenever the preorders are in)
Well you asked if it would work with Oreo so that's what I was responding to.
I didn't mean that post to dismiss your help. I was just fishing to see if anyone here already HAD a Note 9 and had tried it or played with it in Best Buy. Thanks for your help! It is likely to work on Note 9 too. I will check back when people have their new phones. Sorry if I came off ungrateful for your kind help
