Music interuption by Voice Command or Redial when using headphone or aux input.
Stuffie0912
Hey folks... .noticed Droid issue today BUT FOUND A FIX!!! If you start noticing music player skipping around, or it redialing or voice command prompt pop up its issue with the headset jack. I noticed when i used an aux jack in my car when i was trying to play pandora If the jack has 2 rings on it then it should work fine. If the jack has 3 rings on it then it has built in microphone. Android systems have common problem. The accelerometer is close to the voice command censor
After researching online I found this a long standing issue among Android systems HTC and also Blackberry. For Droid systems i researched a few forums with various trouble shooting ideas. There is a widget available through market place called "headset blocker". THIS FIX IS AN ANDROID FIX so far only. I have not tested my sons black berry yet
fidsomedia
