My 1st issue on S7 edge
mc4nam
302
This just happened for a 3rd time today. Home button would quit working and my recently used apps button quit as well. Back arrow would work. All app functions work fine. The only way to get back home was back button.
Restarting fixed each time.
Any suggestions?
You shouldn't have to deal with problems from the get go. Return the phone for a new one. S7 is so new there shouldn't be any refurbs. Go for it now!
Did you end up doing anything about this? I'm having the same issue - just started about an hour ago (got the phone yesterday). The home button works to wake the device, so its reactive but once I put in my pattern and get on the home screen or in any apps the home button does nothing. I can also boot into recovery by holding home, power and up so I dont think its a hardware thing, its got to be software, but can't tell what triggered it to start.
I have not. It hasn't happened again but rebooting fixed for me unlike for yourself.
I will probably get closer to my 14 day return and call in.
i would try uninstalling any recent apps, or any apps you used close to when it first started happening. it doesn't sound like a defective phone, and being that there don't seem to be any widespread issues like this (mine hasn't done anything like that yet) it seems like it's something you may have installed or started to use recently...
"Javier P" mentioned something about a MM bug in this thread. Might be your phones are experiencing something similar. I haven't researched the bug, but something for you to look into.
Try to do a factory reset and see if the problem persists. If it does take it back and get a new one.
Tried that.. I only remembered 2 or 3 apps from the last update and I took those off and rebooted and still had the problem. I don't know if that was everything recently updated but I may try a few more.
I was trying to avoid that just since I can't do a full backup (not rooting).. I have everything set up the way I wanted.
The button itself definitely works -I can do a screen shot by holding home+power - so its registering for certain things.. definitely seems software related, not hardware - I tried powering on in Safemode but still had the same lack of functionality so I don't know if its a 3rd party app.
Well, after I rebooted to get out of Safemode it cleared out all of my folders so I figured I might as well do a reset.. Just tried and its working now. I'll keep my fingers crossed - Hopefully its nothing widespread.
Which carrier? If different people are having the same issue and are using the same carrier, then it must be a carrier specific issue.
If restarting your phone temporarily fixes it I'd imagine it's software causing the problem and not hardware. Strange one.
Posted via S7 edge 😍
I have the same issue. Carrier free S7 Edge. After a few days home and recent apps button just do not work. Home button is fine for unlocking but once in the system, it stops working.
I read somewhere it might be some Exchange policy issues. Indeed I need an Exchange account set up, but since then I removed it - the problem still exists.
By the way: for me doing a reboot does not help!
Anyone any idea?
HERE'S a Google search. There's a bug being reported on Marshmallow for many phones on many forums for Nexus, Samsung, LG, etc. With all the bugs when Lollipop was first introduced, is anyone surprised???
Anyone any idea?
I ended up doing a full reset, couldn't find any other way around it and so far it's working fine. I didn't have an Exchange policy set on mine when it occurred - just had a gmail and Verizon mail account (both have been reinstalled after I did the restore).
Mine is a Verizon S7 Edge.
alanmagdaong
