My battery is stuck at 0 - Not charging. How can I fix this?
  • Start date Start date
A
AC Question
Battery Stuck at 0% - Not charging
I have a Oneplus One, my previous battery got damaged and I had to replace it. After replacing it, the phone boots while connected to power, but the battery meter is stuck at 0%, the phone turns off immediately after disconnecting it.
Is there something I could have done wrong?
Do you know how to fix it?
Re: Battery Stuck at 0% - Not charging
Are you using the original battery and charger? Cuz if it's not,maybe that's the problem
be sure that u r using the original battery and charger and check the thing which connects the phone with the battery .. it maybe also a problem in the place in which the charger is connected to the phone ..better to send it to someone to repair it
Posted via Android Central App from Samsung Galaxy Note II
I constaly have trouble with my factory charger and cable. All others I have tried work great, but the factory charger cosntantly stops charging at 40-50%.
Hi fellow OPO's, I'm on my second one because it would not charge. Well I started using android chargers from other phone and my H.P. tablet. Everything worked, so I plug in the opo cable and powered down for the night. To my surprise it had lost part of the charge. I recently discovered that the opo cable should have the flat side to the plus on the part that goes in the 120 v. outlet. All in all I'm satisfied.
mitiku Berihe
