My cherry mobile flare j2 max wont turn on
Macoytapacal
I tried to turn my cherry mobile on and. It just display the boot screen and off again and display the boot screen again in infinite loop...
It doesnt really open up until the home screen...
It keeps displaying
Powered by android go edition....
Turn off again
Display it again and turn off again...
Welcome.
That could be caused by software or hardware trouble.
Try booting into Safe Mode to see whether that helps.
I am unfamiliar with this brand, however it almost sounds like there is a button stuck. Try clicking all of the buttons on the device, volume up, down, home button (if equipped), power button, any physical buttons you have multiple times. Listen and feel if the button has a clear snap and firm return. Then attempt to start the device. I guess I should have asked before, but the device hasn't suffered any damage correct? No falls, no moisture or water, no overheating issues, nothing like that, correct?
Have you tried pulling the battery, if you can pull the battery? If you can just pull it out for a minute or two and then try again.
