My Driod Razr M will not reboot, factory reset, turn on, the light in the corner wont turn on. Help, what should I do?
  • Start date Start date
A
AC Question
My driod Razr M will not reboot, factory reset, turn on, the light in the corner wont turn on. Help
My Driod Razr M will Not do anything!. it work perfect this morning and now It wont even light up turn on or anything! i had it about a year now. Its charging in the computer now and the computer wont even recognize it
Re: My driod Razr M will not reboot, factory reset, turn on, the light in the corner wont turn on. H
Welcome to Android Central! Charge from a wall outlet. If nothing happens after a few hours, try a different cable/wall charging plug. If that doesn't help, then the possibilities include a faulty charging port, dead battery, or dead motherboard. You'd have to bring it to a repair shop to figure that out.
