My droid 2 is stuck on moto M ahh :((((( help please
Feb 12, 2012
5
okay so heres the deal i rooted my phone by droid Droid-lifes onclick root was awsome
so then i installed rom manager tried flashing clock work nothing
down loaded CWM tried booting into work
then i found out i needed boot strap not cw so i got that installed in and loaded up Liquid gingerbread Rom was pretty cool but i wanted to check out the cyanogen mod rom so what i did was this
started up boot strap app and then booted up into recovery from bootstrap and i wiped cache and then wiped data
then i installed the cyanogen mod rom loaded up siad it finished installing so then i clicked on reboot system now
thats when the problem started it was stuck at the motorola M for a long time like 10 minutes or so. of course i pulled the battery and restarted same thing left it for an hour nothing tried booting into recovery it loads up stock android recovery :(
and ideas on how to fix would be much apperciated i have RSD lite on my computer and yes im new to this.
i did perform backups threw rom manager and cwm but they werent zips because i tried putting them onto the root of my sd and loading it up but they didnt show up
any help would be awesome. oh i think my phone to start with was on gingerbread android verison 2.3.3 ? i no it wasnt 2.2
so that was my new rooting experiance
ok so i tried SBF back to stock RSD lite was giving me problems right away but i figured out rename the file i did to ABCD. what ever the file is. that worked and it was flashing my phone but at the end at like 99 or 100% it failed and said secure motorola flash interface could not be found. so i restarted my phone in bootloader mode and it said curropt file. what do i do from here??
im using windows vista running as admin a
ll the correct drivers
im using RSD lite 4.7
i just want to run a rom and overclock my phone but this is turning into a nightmare
any help is much appercated
i only tried turning it on once after i flashed it threw RSD and it went to bootloader..... it was real late lastnight so i dont know if i was holding down the up arrow or not to get into bootloader but i havent tried starting it after.
should i boot it up and see what happens ?? even tho i got that error should it be fine ? and then just ota update to gb and reroot and flash rom?
thanks for the help also scarryman04
Yeah try to boot it up...it might take a while or bootloop again, if it does just do a battery pull and try to boot it up again. No problem...I was a noob once too so I like helping out whenever I can :p
Sweet man if that doesn't work then try the method that is in the first post of the how to that is in the help at the bottom that says corrupt code.
Okay so I'll post up if I got my phone fixed or not because my dad fried my comp so everything might be lost (long story but what ever) ill keep you posted tho on when ever I fix it
Hold x and power while booting phone on...once you see a screen press the magnifying glass button on the keyboard...but that prolly won't work because you have to use the bootstrap to access recovery
Twousay
