• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
my knox for Samsung s6 edge not adding fb app
Guy Levi
Hi guys I've just discovered my knox. Great app. I've got it setup and most my apps added. How ever I can't add facebook app. The Facebook messenger app is added fine but the actual Facebook app itself doesn't appear in the list of apps to add to my knox.
I have also tried uninstalling and reinstalling the app but still no change.
Anyone else had an issue ?
praveshraheja
Re: my knox for Samsung note edge not adding fb app
Same issue with me also and if you got solution please tell me .
i think there is another way to do this set up
KennyG944
Why not just reverse the two. Put all your personal contacts within KNOX and install any apps you don't want to have access to your contacts outside of KNOX. Correct me if I'm wrong, but it would be a nice way to deny apps access to your contacts. :)
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
Why would you download and activate Knox unless the company you work for requires it? (If you didn't download the actual Knox app, all you've done is turned on the hook that the app uses, and it causes problems if you use it that way.) It's not a "great app", it's an app that keeps you from doing anything to apps or data installed in it. Samsung's way of letting your company control a phone you paid for.
