My Nexus 4, why doesn't my screen turn on when locked and when there is an incoming call?
yon-yon
Lollipop, Nexus 4, screen doesn't turn on when locked and there is an incoming call
since upgrading to android 5, the screen doesn't turn on when there is an incoming call, and i have to unlock to answer. (and now it takes twice as long to unlock, why oh why did i upgrade).
i couldn't find an answer to this question in the forums...
please help
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,948
5,258
113
Re: Lollipop, Nexus 4, screen doesn't turn on when locked and there is an incoming call
Welcome to Android Central! Do you have any other lockscreen apps that were previously installed?
John Harper4
It is happening to me too since upgrading. Has anyone an answer?
gn2moab
15
I found that the camera flash on ring notification is the culprit on our nexus 5. I disabled it and it works fine now.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,948
5,258
113
I'm not familiar with that setting--is that on a stock Nexus 5, or are you using a 3rd party app?
smokinguns
I have the same issue. I've tried to increase the sleep duration from 1 min to 2 mins and it didn't do the trick.
When I Sideloaded the APK file, i had this issue and after an attempt to re-lock the bootloader - the issue went away and now it's back again. I am not sure what fixed it but appears to be a configuration of sorts to be broken as the issue re-appeared.
Did any one have any luck with this?
I can't find any Flash notification in Accessibility settings (that's where its supposed to be) on Lollipop on my Nexus 4. I know that iOS has this feature as it doesn't have a notification indicator.
Update 2 -
Guys.. Looks like some others on Nexus5 Lollipop have the same issues and found the culprit.
If you're using Velis Auto Brightness then disable it for now. There appears to be some bug that has been acknowledged officially
forum.xda-developers.com/showpost.php?p=57202129&postcount=1580
And I believe a fix is on the way.
Llop719
