My Nexus 6 has charging issues. What can I do to fix them?
  • Start date Start date
A
AC Question
When i put my phone on charging it stays on the same percentage of battery even after an amount of time. I've to switch the phone for it to charge.
Re: My Nexus 6 has charging issues.
Try first a Cache Partition wipe.
When I bought my N6 a few months ago the charging cable the came with it, did the same as you are experiencing. I tried my cable from. My Nexus 9 tablet and it worked a treat. Try a different cable.
I would also suggest the same as above. I had a cable go bad. It would show that it was charging but it would never increase. The power adapter was still good. Also could be the other way around. Adapter bad with the cable still good.
Mine was problem with plug contacted Google they shipped new one
Naughtlisaes
