my notifications for text only work ramdomly. no light flashing and no sound
  • Start date Start date
A
AC Question
I used to get text notifications. no nothing. I have to keep checking my phone for texts
Welcome to Android Central! Which phone? Does this happen only when you have the Messaging app open, or also when the phone is asleep?
Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
NameRingtone
