My phone function does not work, Why?
eldub1
811
48
i have 2.1 rooted stock rom and no phone function. why? Will a diffent rom solve the problem?
The above guy was cute, but I'm sure you are frustrated. If you need help, you need to be more specific.
Do check volume controls in case you had been using headphones (that is a habit from my old Pre).
What Rom are you on? What root method did you use? Did you come from stock 2.1 or had you updated to DK28?
Have you tried a hard reset or reboot if you are in clockwork?
There are also stickies at the top of the forums and in the Development section that can help you fix a problem, look through those but I'm not aware of any addressing this.
No one can help you until you provide more information. So tell us what you need and don't forget to push the Thanks button for those who help you.
alexanderjames
