My Phone Won't Turn ON (Pls Help)
hell911
242
4
today, i acivated the lock screen password, restarted the phone, now it wont turn ON. there is no logo screen, and no vibration.
i tried removing and plugging again the battery, still no luck
removed battery, connected usb cable, press power button, no luck.
should i call at&t? what do they ask for when i need to replace the phone?
pls help.
checked the battery, inserted it into my friend's phone, battery is fine.
cable is also fine.
i didnt root/rom.. use any kind of custom installation.
pls help.
it wont vibrate, no sound, no login screen.
I personally have no idea.. I would try doing a hard reset if at all possible, if not then I would definitely call ATT .. They will probably ask for security info for the account to make sure its actually your account.. and idk about ATT, but I know with tmobile they send you a new phone, then you just return the old one in the same box.
hard reset has something to do with volume button right? i did that already.
what security info do they ask, do the ask for like receipt or acct number, or something?
