My S3 Problem..
syphonsphere
11
I gotta ask if there is a defect with mine. I would surf the net and my phone would be hot. 40c-44c for battery. Now the front bottom screen by button is hot. I'm guessing processor is there. it idle at 15-20%. Now if i play a game like order & chaos, the game will play for 10mins and start pausing. "lag". If I plug it in and surf or play a game. it'll restart the phone. its that hot on the bottom screen. thanks for your time..
unplugged, it runs the "apps" fine. Just gets hot. Games they lag or stop for 1-2sec. some force close. I took it in tonight and they gave me a new battery. I can't have a phone that restarts every time i charge it and do stuff on it at the same time. I did the restore thing. New battery is at 100% and I'm browsing the web. its running at 39c. nothing else running.
It could also be software. Try a hard reset first.
Also pull the battery and reset that as well.
Sent From My Samsung Galaxy SIII
At AT&T they turned off the phone and pulled the battery. When i got home i did the hard reset. I'm trying order and chaos right this now. bottom of glass is vary warm. game still stalls every 5 sec. I got a good wifi. WoW my ping is 53. I'll say this it makes my hand sweat...
Definitely do a warranty exchange. Sounds like something's wiggie with that handset..,....:eek: :what:
sent from my Galaxy S3 using Tapatalk
Glitch ditch decoder
