My S4 battery is draining insanely fast and I don't know what to do!
thekiomanSKI
5
About a month ago my battery started draining a lot, I would go to sleep and my phone would be a 100% and wake up with 60% and now it's gotten worse.
thatguy97
767
Well you charge your phone overnight right? But that really is a big drop you probably have an app that's doing ALOT in the background
extraclass
618
4
A lot of Apps keep running in the background even if you go to another App! Press and hold the HOME key and you can see the Apps that are still ON! Press CLEAR at the bottom right of the screen to stop these Apps. A weak phone signal or WiFi connection will drain the battery faster than normal.
I charge my phone all night and unplug it in the morning! Works well for me!
thekiomanSKI
5
Also extraclass u might not want to charge your phone overnight as I used to and my battery had expanded and because of this my phone kept switching off randomly and I had to go get my battery replaced.
RUPAASH KANNA
4
Try to disable samsung apps which u dont use..... In settings >application >all this can control from running background nd save ur battery
GodofFire
