• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
My sPen doesn't sound an alarm either when removed or when left.
  • Thread starter Android Central Question
  • Start date
A
I've turned off/on every applicable button: Alarm, Power Saver, Sound, and I've also checked the sound on the phone. There is no noise when I take the phone away from the pen, nor when I remove it from the holder. It does vibrate but very slightly. Another problem, which isn't as important but would be nice if it worked, is this. It will not show any information when I hover, although I can see the small pointer. Everything else seems to work just fine.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
It's in settings, under SPen if I recall correctly.
The hover setting should be in the same area, but I think it's under a different main subject (but also in settings).
