MyBackup Pro issue...won't restore...
rebelguy
54
So I am back to the Rezound after a crappy experience with the GNex. I backed up all my apps and data before I returned it. I copied those over to the Rezound but my backup pro is showing nothing when I try to restore. I even created a custom folder and verified the path. What am I doing wrong?
Make sure your on the same sd card with both the custom folder and the mybackup pro path to that folder. Like most programs mybackup pro defaults to the internal sd card but the path can be set to the removeable sdcard.
You might have created your custom folder on both sd cards., moved your restore files to one of them while mybackup pro is looking in the other one.....been there done that...
internal sd card path :
/sdcard
removeable sdcard path:
/sdcard2 AND /sdcard/ext_sd
omgitsjoshitos
