N9 crazy problem
superdead
4
hello all my N9 started behaving very very strange to the point that i cant use it . it started with random shutdowns later on it just stoped turning on . when i did manage to turn it on there would have been yellow spots all over the screen until it would turn up then shutdown right away. i tried making factory reset that worked !. but the problems stayed. because i purchased it in the US but i live in Israel i cant really use any warranty that i might have had so i gave it to a shop in my city to try to fix it . the shop seller said he cannot do nothing that he checked its not the battery or the screen itself and it might be a version problem or the HD itself. he said all so he tried burning a new image on the device but was not able because already did a factory reset ( some check box is not turn on anymore and he cannot change it ) have you ever heard about such problems is there is thing i can do \ try to make it work again ?
no still in need of help , and i was afraid its a hardware problem but the teach guy said battery and screen is ok
so if not its like cpu\ram\hd ?
can they be replaced if needed ?
having hard time answering on PM for some reason.
please me pm contact derails so i can contact you via FaceBook\telegram\Skype any way you can help .
thanx a lot !!
jenleasch12683
