Need 6.5 Inch Phone - Please Suggest a Few
koolx
67
I need to buy a 6.5 - 7 inch screen phone. One that works on T-Mobile USA 4G LTE or 3G network. What do you guys recommend?
How about 6 inch?
ZTE ZMAX Pro | Read Reviews, Tech Specs & More | T-Mobile
Sony Xperia Ultra Z (I owned the first gen model of this phone and loved it!)
Nahh.. I prefer at least 6.5 inch.
As for the phones you suggested, the Sony phone has a small battery about 2700 mah, very subpar.
The ZTE has weak color calibration and more importantly, its got a weak processor enough so that playing 3D games is slow and useless.
And they're only 6 inches. As I said I need at least 6.5 inch. But let me know if you got other suggestions in mind.
Appreciate the effort nonetheless.
Generally those larger phones are usually European models without the US LTE frequencies. BUT you might be ok with this.
Look for the Samsung Galaxy Mega 6.3. It's not exactly 6.5 inches but it's 6.3 which is the closest you might find. I wouldn't even call that a phone anymore but instead a tablet or a phablet. I believe it's from 2013, so the specs may not be top notch.
I'm not sure I can recommend the Mega, it's specs were under powered EVEN back then! It does have the size. HTC did a large phone too, the HTC One Max, I believe, but again it was under spec'd.
I just got (or will be getting, it's coming Tuesday from the Fedex man) a relatively big phone myself, the Huawei Mate 9, at 5.9 inches. It's apparently not big enough for him. ;) Now THAT phone has flagship specs!
Awesome! Hope you get it soon - maybe even sooner than Tuesday! :)
