need a lil help
dwzl78
4
I have an Evo. It is flashed to cricket. Its running GingerAle V5RTU. My voicemail Notifier doesn't work, my HTC Sense doesn't work, HTC Hub, nor Sync work, why not?
Does anyone have a link to the gingerale v3 download? Or to any evo 4g rom that has no bugs?
I have never owned an EVO 4G. Take a look in the forums. It could have just been a bad flash. You may even wanna re-try pressing that ROM back down a 2nd time just to be sure it has errors.
Reactions: dwzl78
Thanx. I learned I had a corrupt SD card. Wiped it COMPLETLY clean, and re-downloaded Ginger ale and started fresh. So far so good. Except my incomin mms messages are time stamped two hrs off and a few apps won't connect to their network but I don't use those much. I like this forum.
alexypp
