Need a quick hand-Odin not seeing phone
anon(94115)
Banned
Nov 29, 2010
5,697
511
I know that this has been an issue with several others, but for the life of me i cannot find any threads on it. Right now I am sitting at stock Froyo and no matter what i do, the phone will not go into download mode or will odin see it.
I have:
Tried different USB ports
I am using the stock cable, I have 2 of them and tried both to no avail
tried downloading the drivers again
tried installing the drivers again (with reboots at every turn)
Tried downloading a new copy of odin
Tried my new copy of odin with several USB ports
I have started with stock and non stock batteries to begin with (meaning put in a stock battery, powered down, pulled the battery tried to get to download. same with non stock)
yes the battery is pulled the whole time
no antivirus is running
Can someone give me a hand or point me to one of the other threads that go into this? I never paid much attention to them since I didnt have the issue before tonight, and I guess my googlefu is weak on this one because the search isnt pulling up anything
Try getting into download mode using your AC adapter instead of the computer... Sometimes the extra voltage is enough to force DL mode
Reactions: anon(94115)
Try rebooting the phone while it is connected to your computer with the usb cable and usb debugging is enabled. If that doesn't work go into usb settings and change it from mass storage to ask on connection.
??????what recovery do u have. Maybe you can flash a rom that has the download option on the power button long press and enter by that means??????
Nope nothing when I pull the battery. Odin sees the phone while it has the battery, but not when powered off...
This is a shot in the dark, but is your anti virus on your computer disabled? I think that was what worked for me once sometime back...
Totally stock. no recovery, not rooted, Froyo kernel and ROM
have you tried a different .. also are you able to connect when the phone is on, meaning can you get an adb connection or is it just download mode the trouble
a different what? USB port? Yes
Yeah download mode is the issue. I can get to the stock blue recovery but it never goes into download
hmmm..believe it or not, I havent tried a different computer because I have always used this one for everything. Let me give it a go on the wifes desktop and if that fails, I have no issue with the screen share
Back in a minute, it is already set up for it so it shouldnt take long
Well chalk that one up to the unexplained gremlins.
I switched computers and boom it went right into download mode. I figured I wouldnt look a gift horse in the mouth, so while I was there I odin'd CWM, then flashed CR 2.0 so I am back to something like normal.
Came back to my regular PC and tried download mode on it (since it didnt work for like a day) and sure enough, it went right to download mode as it should.
Thank you all for the help, I am pretty sure I hit the thanks button for everyone, but If I missed you, I thank you....
glad it worked bro , have a good night
Looks like you have not tried different PC yet? Is this something you have access to? I know I am spoiled in that I have three to choose from in my home... (two laptops and desktop) I always forget that many folks don't.
If not can you phone a friend who might let you borrow a laptop for an hour...
jmarshallcleaning
