Need Advice - Memory Leak
Floridadomer
721
3
My phone is apparently experiencing the memory leak issue that has been reported. I can clean the all of the system cache but it will work fine for a few hours then it will then start to slowly get more sluggish as the day goes on. When I try to open an app like the phone or the stock messaging app, it can take up to 2 minutes to open. When it gets bad like that, I clean the system cache again and I am good again for a few hours. the first few weeks that I had the phone, I had no issues and it was very responsive.
So would doing a factory reset help this at all or is it is what it is until we get updates?
I think its a lollipop issue and should hopefully be fixed in the next update.
Some if not all of the memory leak was addressed in 5.1
From the ZenFone2
Android Central Ambassador Team Leader
It's a problem with the way 5.0 was written and it wasn't addressed until 5.1, so until you get the 5.1 update, you're going to have to keep restarting the phone or clearing system cache.
wobblefix
