need GBA emulator help
fuzzy_jw
4
I have a htc incredible , I have all the bio's and rom .. I create the folders then go to the gamebiod click the games. Then it says, BIOS fails, specificy the settings. Can someone help me plese.
Did you locate the gba_bios.bin file ni the root of your SD Card? And, did you point Gameboid to the gba_bios.bin when it started up.
Also It seems like the first few game ROM's are not playable, but if you scroll down you will see the same roms listed again. Those should be playable.
Yes I have the Bio in the SD card, ive put in the download section and ive made a folder for it.
Ive even tired to download the whole thing from my phone using the Linda File Manger App, still says ( Bios faild, please specifiy the settings).
Am i putting them in the wrong folder? or could my gba_bio.bin file be bad??
Ive downloaded my bios from gamefront and my rom from coolrom.
thanks for posting
it actually says ( Load Bios failed, The vaild BIOS must be specified in the settings).. i just re did everything.
So now what?
Re download the bios file in the browser using this link
Gamefront
Or do a google search for gba_bios.bin there are a ton of mirrors and I don't know which are good or not.
Use the browser on you phone it will download to the /download directory on your sdcard. Proceed from there.
Good luck.
Svenot
