NEED HELP! after rooting
andrew200100 lazo
3
Question#1
ok so i finished rooting my thunderbolt yesterday and i wanted to install the perfect storm rom. so i installed rom manager from the android market and backed up my current rom(default) so now i need to know what to do next
Question#2
after i shut-off my phone when i plug it in with the micro-usb to charge rom manager starts up. is there anyway to fix this?
thank you for any help you provide & sorry if this question was asked before.:)
Download the rom of your choice and place it on your SD Card. Boot into recovery and install from SD card. Don't forget to do a full wipe data and cache before the install.
This seems to be one of the quirks with cwr and the TBolt.
Reactions: andrew200100 lazo
You need to put the downloaded zip of perfect storm onto your sd card via your computer. Then go into rom manager and look for where it says load rom via sd card. Click that and then choose the Perfect Storm zip file that you just placed on you SD Card via computer. Rom Manager will take over from there. Make sure to load a clean rom. When it asks to wipe all info and do back up make sure and check those as well. Hope this helps for question #1
mitiku Berihe
