need help asap tmobile on oreo an lg g6
Goosinurwife
302
it seems theres NO way to disable the tmobile sound at startup in oreo i cant find that anywhere help me i need to disable it asap its drivin me crazy
Could you disable in Nougat?
ya in nouget all you had to do was slide touch feedback and system to zero also it seems the tmobile app resets an trys to take over the phone im screwed i need to get back on the old android cuz this oreo sucks
just turn your phone to vibrate. why are you resetting your phone multiple times?
tiffny
