Need help asap!!!
Armorplays
16
so i was trying to upgrade my galaxy s 4g to stockroom ROM then the process failed then my phone was bricked i kept trying to unbrick it until the process final said it passed, but every time i turn it on the phone shows the word "vibrant" glowing then the phone restarts and loops back to vibrant all over again. how can i fix this since i am only able to go into download mode but not recovery mode.help me! please!!!!
Did you flash the correct rom for your device? where did you get the file?
i used the odin v 1.0 , i got the file from a link [GUIDE] How to Restore or Recover Your Samsung Vibrant on youtube this was the first time trying it so i hope it was the correct rom. i dont realy know what the stock rom is.
Don't quote me but im pretty sure Samsung Vibrant is not the same as Samsung Galaxy S 4g, if it isnt you are going to have a very difficult time recovering your Device. What is the model number of your device
Good plan :)
From my Galaxy Note 2 via Tapatalk
My buddy had thus exact problem. Took me a day to finally find the right rom and get it working. Glad the story ended well.
helps
so i want to make my galaxy s vibrant run CM 10 but i just need help with it. i currently run gingerbread 2.3.6 from kies mini so can someone give me a reliable way to return my phone back to stock with out bricking my phone or show me a way to update my phone to cm 10 a different way.:mad:
Re: helps
if you want to run CM 10 you need to root your phone, i would look over on XDA or rootzwiki for a guide. not sure if cm 10 has even been made available for the vibrant
Re: helps
after root is achieved one would flash a custom recovery, make a nandroid backup, download rom of choosing, factory data reset, wipe cache, wipe dalvik, flash the rom, flash gapps, reboot and enjoy
if you have never rooted a phone i would suggest you take your time and READ READ READ nothing worse then bricking a phone
Re: helps
i brick my phone a good 5 times yesterday so i can recovery a brick like it nothing. is nanodroid and app?
Re: helps
nandroid is a backup of the stock rom, if your bricking left and right you might just want to stay on a stock build.
rooting and roming is not hard but missing steps, forgetting to make backups is a warning to stay stock
johanchsirisa
