NEED HELP - Bricked phone?
shady90
3
Hi!
Some days ago my phone is suddenly died. :-(
Now it is in bootloop, I cannot enter in recovery mode but I can enter in Odin mode.
I tried to flash from odin different recovery (CWP, TWRP). The installation was successful, but after reboot I still cannot enter in recovery mode.
Can anybody help me?
Phone never rooted or flashed.
GT-I9195 LTE - European (Italy)
Original firmware, original rom, always updated.
CURRENT BINARY: Samsung Official
SYSTEM STATYS: Official
KNOX KERNEL LOCK: 0x0
KNOX WARRANTY VOID: 0x0
CSB-CONFIG-LSB: 0x30
BOOTLOADER AP SWREV: 2
WRITE PROTECTION: Enable
Thank you,
Daniele
Do you have an SD card inserted? If so, try removing it and rebooting--sometimes a corrupt card can cause problems like that.
My S4mini (GT-I9190) is very touchy about exactly how buttons are press'd and especially released in order to actually get into recovery mode. (I'm using CWM v6.0.5.1 by arco68.) I have found it necessary to press exactly as follows:
Begin this process with power off (remove battery, wait awhile, replace)
1a. Press & hold Volume Up. While continuing to hold,
1b. Press & hold Home. While continuing to hold (both),
1c. Press & hold Power.
2a. Continue to hold all 3 until device starts up (it vibrates).
2b. Release power button (keep holding other 2 buttons) during vibration*.
3. Release other buttons when blue Recovery Mode appears.
* Vibration lasts a second or two, release only the power button during latter part of vibration, or very shortly after vibration ends.
