Need help...camera on incredible
Tash2311
6
Can anyone tell me what might be wrong with my phone...when I click on camera the entire screen turns pink and it won't focus on any object to capture a picture.
i have no idea but you might give a bit more info for people.
are you stock? rooted? different rom? have you rebooted the phone to see if the issue goes away? try changing settings?
Camera not working
Its stock. Yes I have rebooted and looked at settings
Tash,
I have to ask this but when you say when you click on your camera this happens as you described above... Do you mean when you click on the camera icon to open it or when you actually try and take a picture?
Either way I think as the other poster had mentioned you might once again try a reboot and since you are stock and the reboot does not work I think you should make sure what is important to you is backed up and then do a hard reset to set ALL settings back to factory as it was when you bought it.
That should work out the kinks and then after that if it does not make a trip back to or call VZW and document the issue to see if you can get another phone and start over. Last resort stuff but sometimes it is neccessary.
Good luck and let us know what happened and worked for you in case it happens to someone else.
markojacob
