Need help choosing.......
twindragons187
480
56
I know I know, ive seen these post a lot. But I'm really torn. I have both the gnex and raxr maxx. I love the battery on the RAZR, but I also have 2 extended batters and a stock battery for the gnex. Both phones get about the same dBm for signals. I just wish Netflix was as clear as the RAZR is. My gnex is running jb and RAZR ICS. I would really like to keep both but I can't. So please anyone with a decent opinion? Thanks in advanced
I've seen a lot of people on these very forums fix their issues with the Galaxy Nexus by being swapped into a RAZR MAXX.
Sent from my DROID BIONIC using Android Central Forums
All honesty. The galaxy nexus. You can always count on the next os to come. Of might take awhile since its Verizon but its a for sure the nexus will get it. You really can't make a bad choice. So pick what u feel like is the phone for you.
Ive been thing bout sending the maxx back any way. I'm really into the ROM scene and the maxx is pretty scant on that front.
I like the maxx for the battery size. Other than that. Stick with the nexus. I understand the maxx has a nice screen but its not enough to steer me away from my nexus. The nexus' screen is perfectly clear to me.
BinaryCode transmission from ParanoidNexus via XpTapaTalk2
If you're main concern is ROM-ing and having the "latest" version of Android, stick with the Galaxy Nexus.
All other concerns - keep the RAZR MAXX.
The gnex had its last radio drop(data/voice) that I'm going to take. I really wanted it to work...as I loved the gnex.
Sent from my DROID RAZR MAXX using Tapatalk 2
Reactions: Ry
