Need Help Flashing BB ROM
just download droid root pro from the market recommended
once you have Droid root pro installed get the tools
Follow the steps to get it setup
You can download the rom from Droid root pro
And from that it will flash the rom with 99.0b
Manual way
Follow the first steps to get droid root pro and set it up
download the rom. From the alldroid
Or if you go the manual way get 99.2b or 3b and use the update zip ensure its on the root of your sdcard
Reboot into recovery allow installation of update. Flash the update
