Need Help. How do I delete my swipe?
lovy
693
38
My swipe won't work and tired of trying to figure it out The keypad isn't all that great either it delays. Still a noob and would like to know how do I delete it. Also did anyone get swype from 4shared.com? My son has that on evo and it works great its an apk file.
Are you just trying to switch to a different keyboard or delete it from the phone? Does Swype come preinstalled with the TB?
Swype does not come on the TB. If you get the app from the Swype beta site there is a great tutorial that shows how to install it. Its a multi-step process, but it the latest beta does work correctly on the TB.
If you get an apk from other than the beta site, it may or may not work, but would probably not be a current version.
Hi Sean I was deleting it from the phone my son just told me how, and no it does not come pre installed with the phone. I am going to get the one that is used on the Evo.
