Need Help Please
sniperservice
79
Somehow I put the Quick Remote in my Notification Pull Down. Now, it's taking up half of my area. Can Not figure out how to delete it off of there. It's driving me insane. Hopefully, one of you can help me
Slide over to the right end of the quick settings, tap on edit, and then tap on the checkmark for quick remote to deselect it.
Sent from my Nexus 7 using AC Forums mobile app
At the very top of your notification pull down is quick settings. Slide it till you see the option to turn it off and on.
I think these two are talking about getting rid of quick remote from of your Qslide but if I understand you correctly you just want the remote from taking up space underneath the Qslide row? If so just tap quick remote again in the Qslide so that it is grayed out and the remote will disappear below the row.
Sent from my VS980 4G using AC Forums mobile app
Ariwenni15
