Need help putting icons in the right place on SDCARD!
Downrange
Active member
Aug 7, 2010
28
Okay, I have a folder on the root section of my sdcard that I titled "icons." Whenever I use Better Cut or try to access my icons, I have to use the gallery on my EVO. The problem with this is my gallery is not displaying the icon folders as they would look if you opened the folder on the sdcard.
It seems to be breaking down the folders by icon size and in the process, the folder names are not there most of the time.
Where do I put all my icons so they are in teh right place when I use Better Cut or any other app that lets you use custom icons?
Also, when I open up the "new froyo gallery," its being populated by all my icons! I think its actually tripling my icons by displaying them according to size as I use png icons.
I want to use the new gallery but can't cuz it takes too long to populate.
Can someone help me?
This is a picture of my problem:
As you see, it says I have over 20,000 photos.
I really have less than 1000 on my EVO and most are icons (png).
Why won't it keep the icons together? I have them all in a folder called "icons" in the root section. Tonite, I moved the icon folder to the DCIM folder and it just doubled my photo count to 20,000+.
And because my phone thinks I have 23,000+ images, my gallery albums NEVER load.
okikisodiq234
