Need help quick!!
passion4tech
Banned
Sep 1, 2014
203
Hey guys I need help. I flashed ARHD 11.1 and then I flashed the 4.4.2 Hypernova kernel MassStashedX-FlarPort-0.19.1-Sense and now I have wifi issues. What did I do wrong? Why am I having wifi issues since I flashed hypernova kernel? I have a sprint HTC One M8 on 4.4.2 and my software version is 1.54.651.10 . My Hboot is 3.16.0.0000
Just dirty flash the rom again
Also I' m having boot problems it gets stuck on splash screen and it takes long time to get to lockscreen. When I flashed arhd 11.1 everything was fine, then when I flashed kernel I get boot problems. I fixed the wifi issues flashing newer kernel 4.4.3
Before I update firmware I'm going to try firerwater again to gain s-off
If I update the firmware will it prevent me from gaining s- off?
Yes as of right now even sunshine won't work with 4.4.4 and being you are s-on you would need to use the full firmware package. I would s-off if i were you. I know its $25 if you need to use sunshine but i think its worth it. S-off makes everything so much easier. You can use any version RUU, Firmware ,Hboot.
So what firmware do I need to install? After I install the firmware package will firewater work? BTW I have sprint HTC One M8 and I'm on 4.4.2 and my software version is 1.54.651.10 . My Hboot is 3.16.0.0000 and my os is 1.54.651.10. I'm on ARHD 8.1 and on Hypernova 4.4.2 custom kernel.
I would do it with the version you have, You cant install anything older only newer firmware and you dont want to do that until you are s-off. I would use a stock rooted rom.
ARHD is a stock rooted rom right?
No its modified and also its a port from the international M8.
So how do I go back to stock from ARHD? Again I have sprint HTC One M8 and I'm on 4.4.2 and my software version is 1.54.651.10 . My Hboot is 3.16.0.0000 and my os is 1.54.651.10. I'm on ARHD 8.1 and on Hypernova 4.4.2 custom kernel.
Just flash a stock rooted rom in recovery like you did for ARHD
This rom will work....http://forum.xda-developers.com/showthread.php?t=2716492
This kernel will work if needed....http://forum.xda-developers.com/showthread.php?t=2717690
marksains61
