Need HELP! resolution jacked up
diver6090
14
Hey guys.
I hope some one can help me with this. my budddy at work was showing me how he changes the res on the phone and was using an app i belive is called blade or similar. He downloaded the app switched my res a few diff times and showed me. I thought cool and said so. He then decided to save the settings next time he changed them. and BOOM i can only see my front screen when it starts now and can't get it to do anything after it boots to there. ANy suggestions that are going save his ******ed butt.
I appreciate it and it has root but will not go into recovery screen
:mad:
What happens when you try to get into recovery? You could try to ADB into the phone when its on and see if you can get at the build.prop and modify the lcd density line to stock (160 i believe) but if the program is writing the new value on the fly, then I'm not sure.
If that doesn't work and the program is changing it on the fly you can always use adb to delete the app as well. then reboot the phone. Hope you get this fixed.
richardspi ey
