Need help rooting Dinc
gotbeer5150
Active member
May 7, 2010
29
I have tried several of times to root my Dinc using unrevoked. I have downloaded the drivers need (at1ease i think i did). It does the part where it reboots the phone, then goes into pushing recovery image, but does not go any further than that. I have left the phone hook up in "pushing recovery mode" for up to 30 mins, and still nothing. Can some explain to me what i am doing wrong or what i need do to get this phone rooted.
I think you might find a bit more help in the ROMs/hacks subforum. Lots of very knowledgeable people there.
Howto: Root the HTC Droid Incredible - Technology - Jonamerica.com
I followed the instructions on the above link and it worked flawlessly. Try that.
Took me awhile last night but I did it! Just be patient and don't get frustrated. It'll come easier
If you have HTC sync that might be the problem you need to make sure you remove it from your computer.
I will move this to the hacks section.
