Need help rooting optimus s on 2.3.3
brennon5p
8
I never rooted my phone before the update and of coarse when the update came out i instantly updated not thinking about it. is is possibly to root my optimus s if iv never rooted it before and im running the gingerbread 2.3.3?
Yes and no. You have to revert to zvd 2.2 and follow the zvh rooting guide in the rom section. It is a sticky, right at the top of the page. It will even link you to the guide you need to revert to zvd
Reactions: davidhibbert
i tried that but when i attempt to install the package it says it cant verify signature or something like that and wont let me install it
Does your Recovery look like this?
Please check the top-level of your sdcard to see if you have:
filename: update.zip
filesize: 88,007,618
MD5: 2db9b55305cff37a6b6e402fb8518acf
alternatively please just re-download update.zip from the 2nd link in my signature.
Also if you could list the exact error you are getting, that could help.
.. on a second note, if anyone has the time this sounds like it can be resolved easily. Sorry brennon, if I had the time I would help ya out but im a lil preoccupied today.
Thanks ahead of time to the community for the help with this one :p
its fine i understand its probably something easy and sorry about putting it in the wrong section im still learning about the site haha
In case it got lost
You are absolutely fine. I am just helping you get more results and keeping the forum organized. Welcome to the community! We all started somewhere :) There is never a bad question
im going to retry with your link. if it does have the error again ill take a picture or something so you can see it
thank you for your guys help i did it and it worked! it must have been lost. i really appreciate it guys
im having the exact same problem he was having and the file cannot be found. ive tried downloading the update from many different sources and it still will not work
Negotiabledai
