Need Help... Simple Question
Jonross
Active member
Jul 11, 2010
35
Okay, I am creating this application that can send a custom message to a number you choose...
But it isn't working as i planned.
For some reason it will not send the message to the number?
Could someone figure out why?
I Think i have everything right?
You click the first box, it opens contacts and you select your target.
Then you type your message into the box and press send.
Could someone look for an error?
Thanks :D
I think your problem is in the When PhoneNumberPicker1.AfterPicking block. You do not need to set PhoneNumberPicker1.text to anything because your not using it in your app. You only need to set Texting1.PhoneNumber to PhoneNumberPicker1.PhoneNumber. If you don't understand, I made a quick app similar to what you are trying to do and posted a screen shot below. The only difference is I added a Label to show the user the current phone number they have selected to send the text message to. If you need anymore help I will do my best to answer.
John20
