Need Help... Verizon showing unlocked.. but isn't.
phantom27
8
Ok. So I have a Verizon S4 on ME7. I had rooted it and installed some Mods. I used SuperSU to "remove root" so I could try and exchange it (it wasn't accepting the OTA update because of some of the mods). Verizon wouldn't accept the exchange because it has a small ding on the side from where I dropped it. Anyway... Now when it boots up it has an unlocked icon on the boot loader and it says "Custom" under it.
Two questions:
1.) how do I make the unlocked icon go away (or did I stumble on a way to flash custom roms?)
2.) How do I flash the phone back to stock so I can take the OTA updates. I know there is an ODIN file but can't find it. (I'm on Mac if there is a way to do it on Mac that would be great, if not, then I can get a Win 7 machine).
Please help.
