I am trying to get relocked to except the ota. I can't seem to get to where I need to go in dos. It just keeps saying system can't find path specified. I had problems with this when I unlocked but I can't remember what I did
Reboot your phone into the bootloader(battery pull, then boot up holding power + volume down)
Plug the phone into the PC
Open a command prompt
Type the following:
Code:
cd \temp
fastboot oem lock
At this point your phone will be locked but effectively disabled because you don't have stock recovery. You will either need to RUU or reload the stock recovery partition. I'd personally suggest the RUU rather than replacing stock. Too many people have had issues with dirty flashing the OTA.
**NOTE: loading an RUU will wipe your phone memory
