need help with edge lighing stuff what is smart view
y2jman
694
20
18
yeah so got s20 plus today i got some issues i don't know what to do i haven't upgrade to 11 yet
umm in edge lighting do you have every app on dhoose apps turn on?
what do smart view do i turn on notfications bubbles in develop options
also do i have to swipe in order to unlock phone with in number?
i hope somebody can help me
yeah sorry nervous man can you help me swipe now thing always to display when you put do pin number?
only thing i don't have pic wise is downloads folder from s7 phone so not why that didn't get carried over there besides mesenger album i guess when i install instagram new instagram folder will be created
Congrats!
You can choose which apps for edge lighting, and andriod 11 has under notification bubble for notification
so when i upgrade 11 then i put it on bubble right do i need to have in developers option bubbles turn on? i assumed you have to have edge lighting turn on every app
apprently when i got gmail while ago it didn't light up then i saw it wasn't there so i changed color smart pop up do i need that on?
You don't have to use the developer settings anymore on andriod 11 for notification bubble
what apps or apps supposed to work with edge lighting i don't know like i said i got everything turn on under choose apps and i don't have to have smart pop up view turn on?
also do you think i should go back to walmart tomorrow have guy get the download folder off s7 i assumed that and messeger folder that has a video reason why didn't carry over i guess they were internal storage instead of sd card
See if it starts to work on android 11. You can ask them to try transfer or use smart switch between the device with a otg adapter and cable, not sure you can do it after the phone set-up .
i still don't understand why i'm still 4g i thought this be 5g when i came home put wifi on
so tell me this since still on 10 i got lightliing style basic choose apps all available apps<-is that right then i see smart pop up view i got nothing toggle do i need to toggle stuff on or not
now when i go do android 11 i should get edge lighting notification besides ringtones on phone right when i change it to bubble like messenger and stuff?
Toggle on if you want the bubbles and off if you don't . Example screen shot don't forget not all apps are compatible with bubble chat even if it's toggle on Screenshot_20201222-215628_Settings.jpegScreenshot_20201222-215618_Settings.jpeg
ok i'm still trying to figure out something is phone suppose to light up because i cannot seem to get it working like getting gmail sound but i don't see it light up
am i doing something wrong?
Only gmail? You mean on the lock screen?
yes i see it red but i thought it will light up like my s7 phone it doing blue at the top does edge lighting only change icon but doesn't light top of phone?
Should be able change colors in edge lighting
so after i update 10 to 11 and color gmail is red does it supposed to light up the screen as well or just the icon/detail?
I don't use this feature, just trying to put you in the right direction
how many freaking security updates i need to do on phone already been 5 ok now next want going to supposed to bring me 5g
i guess its going to be a very long night until i get to android 11
theantithesis
